So, when laying out the layers of glass before wet out, I did notice the weave seemed much tighter than the first build. It also smoothed out better and during wet out I had no issues whatsoever with wrinkles forming at the sheer. It could be the boat design but I'm thinking the glass was more flexible, if such a thing exists. It even wrapped the stems almost half way down before I had to slit it lengthwise. I was able to wrap around the edge as well so I need only put a thin strip to cover the remaining stem.
It is 6oz, I have no idea if it is E or S, just what the store sells is what I get, only the one option. I do think the tighter weave is what made it more difficult to flood the two layers, although I have not done two layers previously so have no history to go from. The one fill coat I did last night is smooth on the bottom so it may not take many more coats to be smooth, but pigment coverage will be a factor likely on how many coats I use.
Jim, Alan, everyone, how does this compare to what you use?
