maybe next time I will go straight to the wet out coat after filling with something other than thickened epoxy. All the additional epoxy applications equal much more sanding. I would like to reduce that in the future.
Maybe I misunderstood you in my previous reply. Perhaps you were referring to extra sanding because of the seal coat before applying the fiberglass. Even this shouldn't take much sanding (or no sanding if you apply your 'glass soon enough). Ten minutes or less with a 120 grit pad on a ROS should do the whole hull after a seal coat.
