• Happy Birthday, Babe Ruth (1895-1948)! ⚾🏠🏃‍♂️
Help deciding on a solo tripping canoe design
I like the lines on the Raven ! Good Choice ! If Mem says you can pole it ! I'd go for it !
Ya, the Skilsaw Rocks for cutting Strips !
Looking forward to your build !
Old post and I know that the canoe has already been built. My question for builder is do folks think the Raven can be built as a composite using the cedar strip hull as mold? Or is Is that shouldered tumblehome likely to get hung up and make for problems getting it off the mold?
alsg, While I haven't built a Raven, I did build a sharp shouldered Kite, as a composite copy of my own wood strip Kite. I think the Kite shape is even more challenging than the Raven. I left my stems open, and removed the hull from my plug (the red Kite) a day or two after wet out, just to take advantage of the softer, not full cured epoxy. I had only a little trouble to remove the hull, mostly due to the short time since carpal tunnel surgery. If I had two normal strength hands at the time, it would have been a cake walk.
Built a composite, using a Bell Nexus ( White water hull) as the male mold.
Absolutely no problems removing the hull from the mold. Just leave the ends open.
IMG_3013_zpshv7ddaul.jpg - Click image for larger version  Name:	IMG_3013_zpshv7ddaul.jpg Views:	0 Size:	313.9 KB ID:	125945
I built this for a friend. I had the royalex hull, that served as the male plug.
Starting on the inside. 5 oz Kevlar, one partial 6 oz rather open weave carbon fiber, another 5 oz Kevlar, and a 6 oz S-glass.
I didn't weigh it, as we riveted on the trim, and minutes later it was gone. All I know he was happy !
We are still looking for ends caps.
A Correction is in order !!! I have an additional 6 oz S-glass layer on the inside !!
For a total of four complete layers and a partial.
Any foam or other stiffeners?
I need to make a correction to my lay up !
I have an Additional 6 oz, S-glass layer on the inside.
So four layers and an partial layer.
No Foam. Hull was plenty stiff !
I also wetted each layer, one at a time !
