- Joined
- Aug 10, 2018
- Messages
- 1,722
- Reaction score
- 2,595
Life got in the way a little but I'm still planning. There are SO many decisions to be made before even starting and I am hopeful someone else may benefit from reading what decisions I make and, eventually, how they turn out...
At this point, I am still planning on using locally sourced wood and will likely build with yellow poplar using butternut or sassafras for the accent strip(s), gunnels and trim. I'll be getting samples of each to determine how they sand relative to one another and which colors appeal to me. Poplar, in particular, is easily replaceable in my lifetime so I think I prefer that to cedar and the weight difference can be made up by using 3/16 strips rather than 1/4 inch.
I don't have a router so I think I'm going to skip bead and cove and plane each strip in place to provide a tight fit on the strip above (below) it. I was trying to figure out the best way to do that when I ran across this: https://www.guillemot-kayaks.com/gu...&utm_campaign=RoboBevel&utm_content=endscreen Seems someone else already did the engineering which will save me a lot of time.
If I am correct, the biggest advantage of bead & cove is that you don't see light between the strips while portaging but the biggest detriment is that the beads pull out of the bottom of the cove on tighter turns. I'm thinking that this tool might be a good solution and it seems cheaper than a router table.
Has anyone tried this tool/method?
