In another active thread, I found out that Helman Canoe has been using something called Ecopoxy resin in its canoes since 2010. I thought maybe that's just Hellman's marketing name for some mixture they use but, no, it's the name of an actual product.
www.ecopoxy.com
According to this grammatically-challenged article, Ecopoxy resin is made from non-toxic plant oils, unlike petroleum-based regular epoxy, and:
"Ecopoxy provides many advantages over traditional epoxy resins. In addition to being environmentally friendly, ecopoxy is also less expensive than petrochemical-based epoxies and offers superior adhesion properties.
"Additionally, ecopoxy is stronger than traditional epoxies, with a higher flexural strength which makes it perfect for applications where flexibility is key. Finally, ecopoxy has a low odor and is UV stable, making it an ideal choice for projects that require exposure to sunlight."
Later, the somewhat confusing article seems to contradict itself about cost, by stating: "When it comes to cost, epoxy is typically the more affordable option. However, ecopoxy may be slightly more expensive due to its environment-friendly production methods and ingredients."
What I want to know is, if Ecopoxy has been around for canoe manufacture at least since 2010 and has so many benefits over regular epoxy, why does no one (that I've heard of) use it except for Hellman?
For 2024, Swift announced a secret formulation Epoxy Finish as a $600 USD (same on the CAD price list) upgrade. I've seen Bill Swift videos where he claims this Epoxy Finish can be put on much thinner than regular epoxy, and save pounds per boat, while maintaining or even increasing flexure and strength. He further says the boat weights on the Swift price lists will be updated in the spring of 2025 to show how much weight the secret Epoxy Finish will save on each canoe model. Could this Swift formulation be Ecopoxy?
Anyone who knows anything about Ecopoxy or Hellman's formulation or Swift's new secret formulation, please chime in.
EcoPoxy | High Bio-content Epoxies for Woodworking
EcoPoxy creates high bio-content epoxies made from annually renewable resources. We are the premium epoxy for woodworkers and artist.
