Well, I decided I would build another Raven. Lots of rumination, was going to go with a 15 foot Pal, but I always really liked the Raven, so I will try to build this one a little lighter.
Someone posted a video by Nick Schade, I believe, where he had cut his stem strips into 1/8 inch strips and simply glued them and wrapped them in saran wrap and bent them on the forms. No steaming needed. I really wanted to try this, so yesterday I cut a bunch of 1/8 inch strips out of cedar, and today I got out the saran wrap. Did the inner and outer for the bow at the same time. So far, so good. A little bit of cracking on the outside piece at the hard bend, but I put a clamp right over it, and it seems fine now. I'll pull them off on Monday, and if it works out, I will do the stern stems then too.
If it works, it will have saved me a considerable amount of time. Took me about a half hour to cut 30 1/8 inch strips, and about 20 minutes to glue and clamp the bow stems today. The saran wrap idea is actually pretty cool too, it holds all the strips in alignment during the clamping procedure.
