I saw a Mad River Explorer on CL yesterday advertised as needing gunnels and the ad mentioned the canoe hadn't been used in 12 years. The attached picture showed it sitting up-side down on horses with obvious faded paint.
When I get there the elderly owners (he called me Sonny, and I'm old) had the canoe on the ground, and told me that they "might" have dropped it and there was now a crack in the hull near the thwart where the gunnel/inwale had rotted away.
I ended up buying the canoe for next to nothing as I assumed it was toast but when I got it home and removed the wood, the hull had alot of flex left at the screw holes not at all brittle. (I used a small screw driver thru the screw holes to see if the hull flexed)
The hull was gently used in it's past life, so I'm hoping it will hold up after I fix the crack and replace the wood.
BTW, the interior stains are from being sloopy with Watco and not cleaning it up. They come off with brillo and alot of effort.
If anyone knows of a chemical that would loosen that stuff I'm all ears.
