• Happy International Carrot Day! 🥕
Resuscitating Fish
Heart of the Shawnee Nation
Is there a trick you've learned to resuscitate fish? Paddling with one hand and towing the fish by the tail is only marginally effective. The wife didn't want to eat a fish and my pike had a tough afternoon. Upon release, he would try to swim away and just float back up. Worked on him for 10 minutes and then we ate fish.
I'd be interested to know how you resuscitate your fish.
I try to keep my fingers/thumbs out of the gills when unhooking. I use the lower jaw to manipulate the fish. "Aim" the fish upriver if there is a current.
If water temps are too high its pretty tough to successfully resusc and release.
I've heard the swim bladder can over inflate, which causes the fish to keep floating belly up. Supposedly if you puncture the swim bladder with a hypodermic needle, or something resembling such, you can rectify the situation. This means knowing where the swim bladder is and having something that can release the air without doing damage.
Apparently you kiss the fish
Seems to work for whatever the fisherpeople were returning. seemed to be catfish
I am not a fisher
I am not a fisher
Ha! Catfish 'n carp.... ya can't kill them. I think they will, along with the roach, inherit the Earth after all else is long gone.
Black Fly,
Do not tow them backwards.......I carry a plastic fish gripper plier but anyway you can tow them frontwards with the mouth at least partly open.
If fishing deep water fish like lake trout, I fight them to the surface slowly while watching for them to burp a quantity of bubbles. Usually they are able to swim down to deep water easily if released within a short time of this. If they didn't burp [deflate] they may soon die if not taken back down soon. I carry a release gadget with a 1lb lead weight on it. This apparatus pinches onto the fishes lip and I lower them down on my line. Usually when reaching 25-30 feet, I can feel them get lively and I lightly jerk the line to release the fish. I can't remember the name of the release gadget but there are several on the market.
Those large lake trout are very old and should be released as LTs are very slow growing.
I hope this helps.
Don't pull them backward. You need to get water over their gills so, forward (or even side to side) with their mouth slightly open will be more effective. I fish almost exclusively for bass so I can hold them lightly by their lower lip but you'll need to cradle their bellies or use a fish grip for pike, walleye, etc. Extreme hot or cold is tougher on them and often requires more time to revive them. Also, deeper water fish (as mentioned above) should be fought to the surface slowly. In all cases, unless you intend to eat them, get them back in the water as quickly as possible and don't release completely until they swim on their own. Some mortality is inevitable but there is a lot of info out there on how to minimize it. (Tournament angler sites, in particular, are a great resource for minimizing mortality as tourney folks tend to be exclusively catch & release.)
True, both are unusually resilient.
Recent research from Carleton University has shed some interesting facts on catch and release statistics. Many variables contribute to survival rates of C&R fish, ranging from angler experience to hook type to fish species. The most interesting finding was that in areas that receive a lot of angling pressure, C&R actually has higher overall mortality rates than a standard limit.
For instance, I am a meat fisherman, so after I reach my limit, I usually go home. In the lakes around here, tourists will often catch and release over a hundred fish a day. The mortality rate can go as high as 30 to 40 percent. My four fish is a small amount compared to the death rate from catch and release.
Another interesting finding is that if you badly hook a fish, like deep in the throat or gill, simply cut your line. They found that within three weeks, over 30% of the released fish had managed to shed the hook. If I foul hook a fish, I usually keep it, even if it is on the small size, as part of my limit.
When I do practice C&R, I try not to take the fish out of the water and release it immediately. Using pliers or some kind of hook extraction tool helps a lot. If you keep a fish on a stringer for a few hours, its survival rate is very low.
On the lighter side, I have never understood the American obsession with pike. I don't want the slimy bast@rds in my canoe. Perhaps if i had dogs to feed, or I was starving, but pickerel is a lunch bucket with skin, so easy to clean, and so tasty to eat.
I've got to agree with memaquay as I certainly won't go out of my way for pike either and the pickerel he refers to is the walleye to most folks. Unfortunately we don't have walleyes here so I have to settle for a small lake trout now and then.
When fishing for lake trout, I use a lure large enough that they can't get it back to their throat area.......lip hooked fish should have a better survival rate.
Geeze Louise, dont get that started again.
As Mem can attest, Karin and I are big C&R people because we like to fish. I can see mortality rates being high in a hi pressure area with occasional anglers. With pike we try to slip the hook in the water or just out of it without handling the fish. Badly injured fish are keepers for sure, and pickerel have to be mighty lucky to get tossed back in the water. I have really come to love the live well in the Lund we rent on our boat fishing expeditions. We also use barbless hooks and that helps a lot. It's the law in Manitoba so we have gotten used to it. It also helps when you are trying to extract one from yourself too.
I once saw karin work on getting a hook out of a smallmouth bass for almost an hour. Frequent trips back to the live well and careful handling resulted in a lively fish release when she was done. I wish more people were like that.
As with anything in nature...the death of one creature often provides life for many others.
Christine ( future worm food)
Seems like pike are the ones that swallow my lures the most. I always eat those guys, even though I prefer walleye or trout. The meats pretty good in pike, if you can get past the slim and bones. I always use lip grabber unless it's a bass and I know I won't hook myself. Play em out is my motto. I use mostly jigs with tubes and grubs and avoid treble hooks generally. I do keep some barbless lures which make things sporty.
I have a few comments - Use a rubber net, which lets you lift the fish and get access to the fish without damaging their gills or taking the protective slime off of them. Second, if you are going to release the fish, crimp your barbs down, it will make it easy to release a fish without excessive handling, and in the long run make you a better angler, as you are not relying on the barb to hold the fish, but your tension and play on the line. Always have a hemostat or pliers handy to garb the hook and twist it out. If I have a fish I would release and it has swallowed the hook, I cut the line. The fish is worth more than my 89 cent fly.
As far as resuscitating a fish, move it forward in the water running through the mouth and gills, when it swims out of your hand, it is ready.
Mem- them pike are good eating if you get the Ybones out. Not as good as splake, but still good.
Hadn't thought of that, but landing a frisky bass in a canoe with a lure hanging from its face ain't my idea of doing it or me any good. Play 'em out and unhook in the water. Never seen one go belly up from that. I've tried several nets. They always end up needing repairs before the trip is over. Never seen a rubber one though.
Lake Trout are one of the few fish that you can pull up from the deep and the don’t need to be fizzed. Big Walleye and Pike don’t have the burping ability. Can’t speak to bass but I thought they were shallow water fish anyways.
If I have a lethargic fish to go back I usually just grab it by the tail and gently move it back and forth until it swims away. I too am a food fisherman and I don’t often put fish back.
Pike are delicious. Ling or Burbot are also delicious and equally disgusting to catch. Still better a Talapia from the freezer at the grocery store.
A little note about hooks; Do Not use those plated ones! a plain iron hook will dissolve fairly quickly from stomach acids, but a plated (or painted) hook can last for years, I once caught a brown trout with an electroplated hook in it's tongue that I recognized as coming from a company that had been out of business for almost a decade! It had been in that fish's mouth for a long time as the eye was rotted away (I suspect a snap or leader had been on it and had eventually worn through the plating)
