What about a Wenonah Moccasin?
SW Idaho
I see one for sale here cheap. Possibly a fixer-upper. Haven't had a look at it yet, but I wonder if it's worth my time.
I'm unfamiliar with that model. I looked it up and it seems like an odd boat. It's built specifically for kneeling but has apparently no rocker and is not meant for big water. Sounds similar to the Whisper except for the seating arrangement.
I don't know how cheap you mean by cheap but if it truly is cheap it might be a cheap way to have some fun in a unique canoe.
If it was mine I'd set it up for sitting and use it as a quick day paddler.
I had a 1999 Moccasin in Kevlar Flexcore for a while. Kruger design, but mine was ordered with the Wenonah sliding bucket. It was pretty quick and narrower than most of Wenonah solos. One of the canoes I regret selling, but too heavy for me in that layup with gelcoat. Definitely worth your time.
This is the boat. Definitely going to need work, but maybe not too much. I'm going to see it in person this evening.
Okay, it needs a little work, but for $175? Why are you still here!
He's not available to show it until later today. ;)
It's been a while since I've done a restoration. From where I sit, this one looks like it could be fun. It's not like I need another flat water solo, but who knows? Maybe at least I can save a boat and compare with what I have (Clipper Solitude).
I don't think I've ever done a restoration, nor am I likely to. What I have done plenty of times is put a canoe back in service. Putting them 'back in service' is a lot faster and less money and you get to paddle them sooner. And you also don't care so much when it bounces off a rock.
It seems like a very cool boat, I'd like to try one (Carl's Paddlin has a used one). Some of those edgy, not-for-everyone boats from the past can be the most charming.
Sometimes, I think, the marketing folks can target a specific paddler to excess and thereby alienate others, causing the early demise of a model. I think the Moccasin may have suffered that fate. When one hears “made for kneelers” most think “tippy when seated”, but it was not the case (admittedly mine was a sliding bucket and slightly lower than a hung seat). I had two Scotty mounts on mine and fished a great deal from it. Never felt uneasy in her.
When I say "restoration", that's what I mean. :D
Well it's not as bad as I thought it might be. The skid plates have been shaved down so that they're very thin. Don't know for sure what's under there, but they're very smooth and don't appear to be hiding a lot of damage. At any rate, they don't look like they're going to be coming off, and maybe won't effect it's efficiency much.
The hull is very stiff and has no cracklies when pushed. The tape was over what he said is a crack. I doesn't look like anything that's spreading or spidering, and I actually can't see the crack on the outside. The tape's been on there a long time and left a lot of glue residue when I pulled it. Haven't pulled the inside tape yet, but there isn't much if any movement there. I think it's going to be a straightforward repair.
The seat is baked. The caning will probably fail. It hasn't been padded in years. It's been stored either inside or with the fabric cover - which he included. That cover alone is probably worth at least half what I paid. It's one of those that zips up and completely covers, but actually sized for a roomy tandem.
Probably won't get to it for awhile, since I have a major yard project taking up my time, and I still need to try making that paddle - and well.....it is paddling and camping season after all. :)
I might lay some new tape on it and put it in the water though. :D
Yeah, much nicer than the one I have here. And with two nice paddles.
Kinda funny that it's in the same neighborhood where I found my Dagger Sojourn.
So, I pulled the tape off the inside of the crack. It's not terrible. I think it's going to be a pretty easy fix - when I get around to it. Not going to try putting it on the water until get that done. I'm going to pull the seat and get a good look at it. Maybe varnish it if it looks like it might hold together. I can slip that part of the project in between the other work I'm doing around here.
I finished repairing the Moccasin as outlined in this thread a couple days ago. Took it out for a spin this morning.
First impressions...
It's a bit more wiggly than my Solitude is with its seat in the middle position. If I raise the Solitude's seat to the top position as I did a couple days ago, it's more sensitive than the Moccasin when kneeling in both. Unless the seat is raised all the way in the Solitude, it's a little tight getting feet under it.
I didn't try sitting in the Moccasin, because the cane was already making crackly poppy noises. Going to order a new contoured seat before I paddle it again. I think it will still have plenty of foot room under the seat with the contour, and should gain some comfort and stability.
It seems a little more efficient on the water than the Solitude, but that might be because I was kneeling. I'm almost always sitting in the Solitude. For sure, it has good glide and it's easy to get it moving.
The Moccasin catches more wind than the Solitude. No surprise there. It tracks about as well, but turns a little easier.
A few wake boats were out on the lake today, of course, and the Moccasin handled the waves (some of them breaking) nicely. I felt very comfortable in it. It's a little lighter than my Solitude. I think I'll keep it.
Still probably going to favor the Solitude for fishing, although I wouldn't hesitate to fish from the Moccasin.
Gotta get a buddy to join me so we can do a more direct comparison.
Got the contoured seat installed, and took it out for a spin today. I like the seat, and I still have plenty of room under it - but I'm going to raise it a bit and see if I like it even more.....or not.
Weather defied the forecast (again) and I had 20+ mph winds. The long fetch and wake boats made things..... interesting. But the boat felt solid on the waves. Would have been really interesting to jump in the Solitude and compare how the two perform in those conditions. I suspect the Moccasin would be drier but the Solitude less bothered by the wind. I'll probably get a chance to do that soon enough.
Lately, I've been choosing the Moccasin for most of my day trips on the local lake. It's becoming evident to me that this canoe, when paddled empty, presents significantly more sail to the wind than the Solitude. I'm going to have to see how it does with a moderate load. At any rate, it still tracks well, so long as the stems remain in the water (as opposed to high-centering on wake boat waves ;) ).
Something I noticed today while looking at the canoe resting on my roof racks...the stem hights don't look as different as the Wenonah specs imply....
Now, I know it's not easy to measure these things perfectly, but when I put a tape to it I'm not seeing more than an inch difference between bow and stern. I'm not sure that it matters - certainly nowhere near as much as weight distribution and trim - but just something to note.
What really matters is how it paddles. It's still early, but my impressions are still that it moves easy, tracks very well, and stays dry going straight into or out of some pretty big wind waves. The Solitude, however, is easier to handle in wind - as was also the Dagger Sojourn (wich is an unfair comparison since the Sojourn was significantly shorter).
I think this Moccasin is going to be best used with a generous tripping load.
