How Does David Yost Build His Plugs…?
Guys,
This may seem like a frivolous question but it’s something I have been curious about for some time. With the recent announcements of several new swift boats and some images/videos of same, I again am wondering.
Is he using pine, cedar? Strip thickness? Stems/stemless? In a couple pics I’m pretty sure I see butt joints as well.
I always enjoyed old threads where conk and others related to the industry would show some of their building techniques etc so with these boats I’m just curious, there is no particular reason I’m asking lol but wonder if anyone knows.
Thanks,
Moonman.
I’ve worked with someone that made a strip boat then used that to make a female mold once that was tested she had me finish off the stripper so she could sell it.
Guys,
Thanks,
Moonman.
I'm also very curios and want to know more about the design and development. I don't know what kind of wood they use for the Swift prototypes but I have seen that at least some of the prototypes have been built with stems and those were laminated from what looked like 1/4" or thinner pieces but the laminate was in the lengthwise direction of the hull, not like a regular two piece stem which is layered perpendicular to the length of the hull. Take a look at swiftcanoeandkayak on Instagram. There is a recent video of the Cirrus prototype that show some close up shots of the hull. I can't say what kind of wood that is but I'm sure someone here will know it on sight. It has some type of stems though. This little solo prototype also features no less than seven thwarts which is probably to make sure that the hulls intended shape is not compromised during the testing stage.
Back in the mid 90's, Mid West Mountaineering, at one of their Spring Events, in St Paul Minn. Had David Youst there, and he gave a nice seminar on how he designed canoes.
At that time, Ted Bell had the Magic, that was designed by David Youst.
One of the best solos out there.
I absorbed as much information, as my Pee Brain could, of David's words and drawings on the Paper easel.
David was then and now Inspiring !
The Plugs that I have seen ,of Gene Jensen's,( Wenonah Canoe ), were built without Bead and Cove, and looked like pine was used.
It was said Jensen turned out plugs in rapid succession.
His main consideration, was Function over Beauty ! Changing a design if it was a 1/4" off.
