'new' Bell Morningstar
@BobMills did you ever move forward with your modifications?
I've paddled my Morningstar a bit more now, and have decided that I'm too short (5'6") to make good use of the center seat with the hull width there. I've soloed it a bit sitting in the bow seat facing backwards and feel like the boat performs well enough that way. I plan to remove the center seat and maybe even the stern seat to reduce weight. If I get really crazy I might try to take the bow seat off the sliding track and just hard mount it. I suspect I need to put in a thwart where the stern seat is for structural rigidity, maybe using the forward holes to try to center it along the length of the keel.
Hopefully a rear thwart and center yoke, along with the bow seat, is enough structural integrity for a 15'6" composite boat? Thoughts, anyone?
I'd say that will be plenty strong.
Since it's an asymmetrical hull have you considered removing the front and center seats and then adjusting the position of the rear seat forward? This would be the same effective position as paddling in the bow seat backwards but the rocker would not be reversed.
Tsuga8, did you ever do anything about the dry inside kev layer? I think this has been suggested as a treatment for "Bell blush" and should be good for that starved inner layer as well.
System Three Clear Coat
My primary poling canoe is a Millbrook Coho. I ordered it without seats, and it weighs just over 40 lbs empty. When I want to paddle it, I use this.
It just happens to wedge perfectly out of the way under the yoke when I'm not using it. And when I am using it, my weight and the texture of the floor keep it from moving around. I have no desire to ever mount a seat in that boat.
By the way - I am in need of a pole racing slalom boat that's a whitewater boat, highly rockered and snub-nosed and wanting to turn on a dime. If you ever decide to unload that Souhegan, we should talk. :)
Would that System Three epoxy be UV resistant? If not, you'd also probably have to slather varnish all over the canoe's interior, both the epoxy and varnish adding weight. Bell blush can be removed weightlessly with acetone, until it happens again.
I use Flood Penetrol on the outside and inside of my Bell canoe, which is a quick wipe-on/wipe-off procedure. The protection lasts about a season.
A good point in theory, but I wonder how much difference it would make in practice. The rocker is an inch different according to these old specs, but since at this point I'm mostly planning on using the boat for solo day outings, often with pole, sometimes with mutt, it's likely it will be out of level trim for much of the time anyway. So I'm inclined to avoid drilling holes in thwarts at the moment. @Steve in Idaho 's pedestal might be a good solution, but the bow seat already provides some ability to adjust trim as is. I can move it about 2/3 of the way towards center and still kneel comfortably and feel like entrapment isn't an issue. Not the way to make the best use of a such a well-designed hull, I know.
As for the "Bell blush", I don't think I've heard that term before - what exactly does it refer to? I have to admit I haven't had time this year to do any of the maintenance discussed previously in the thread. Maybe I'll at least get to the wood work over the winter, but more pressing house projects keep getting in the way.
As for selling the Souhegan.... the Morningstar hull is in good enough shape that I can't bring myself to use it on my bony poling creek, and I actually managed to convince a couple friends (including a CT member) to come trying poling, so I've been using both the Souhegan and the Heron for moving-water poling this year. The Morningstar has been nice for swamps with variable depths - flatwater poling and paddling. But, if I do get a mind to sell the Souhegan, I'll be sure to let you know, @Steve in Idaho ! Meanwhile I should probably figure out how to maintain the hull, as it's picked up plenty of superficial scratches while I learn what's really too shallow and what isn't. Do you do much maintenance on your Coho hull?
....if I do get a mind to sell the Souhegan, I'll be sure to let you know, @Steve in Idaho ! Meanwhile I should probably figure out how to maintain the hull, as it's picked up plenty of superficial scratches while I learn what's really too shallow and what isn't. Do you do much maintenance on your Coho hull?
Nah. The bottom is covered with surface scratches. It's all superficial and purely cosmetic. The only maintenance I've needed to do is on the wood. The S glass skin is extremely abrasion resistant.
BTW, I've never paddled a Morningstar, but I've read that it is asymmetrical and that paddling it in reverse doesn't work well.
I thought it was fine, but then again I have years of paddling tandems backwards solo with less than ideal trim. It's never great in wind and it never tracks that well, which is why i finally broke down and got a real solo, a NS Phoenix, a couple years back.
(Recently I've done a little flat water poling in the Phoenix while tripping in the Adirondacks, in small twisty streams with noticeable current but no rocks and few obstructions. With a pack in the bottom I thought the Phoenix wasn't too tender at all, but not sure I'd do it in swift water where you really need to lean and carve or do evasive maneuvers.)
At any rate, even backwards solo, the Morningstar is much nicer that my Heron to paddle. I'm sure it'd be even nicer going forwards with proper trim.
That's all good to know, thanks!
Poling the Phoenix......oh, you're going to cause me trouble. ;) I had shelved the Phoenix quest upon acquiring the Wildfire, but that tidbit changes my attitude a little. I can pole my Clipper Solitude on calm water, but it's not really maneuverable. The Wildfire....well, you know. But I am as reluctant to stand in it as I was the Dagger Sojourn. Maybe I shouldn't be. I wasn't afraid to pole the MR Guide even in some pretty shaky water. Maybe it's just unfamiliarity.
Yeah..... that's it. No need for the Phoenix. Until the boat fund is full again anyway. :)
I'm not sure the Phoenix would ever be a good boat for poling rocky moving water....and not sure I aim to find out unless I can borrow someone else's IXP haha. But, maybe if I get more poling time in it....
The Souhegan and Morningstar were both attempts to find the lightest possible boat to pole rocky moving stuff. I have also decided I need to use what I have for now. I told the wife no more boats in without one going out first. Really I just need to work out more so lifting a heavier boat isn't a chore. You still won't find me in a 20ft EM White though!
I do also want to do some comparisons btwn the Souhegan and Heron on the same day in the same water levels. How much difference does the boat really make, relative to the skill of the poler (or paddler)?
IME, it can make a lot of difference. Maybe more than I see when paddling, in some cases. Of course, the bigger the difference, the more you notice.
Take my Coho compared to the NC Prospector 16, for instance. The P16 turns way easier, but the Coho goes up against the current easier. Taking that further, the OT Penobscot goes against the current a little easier than the Coho, and the Malecite turned stern forward goes upstream even easier than that - but I wouldn't take it up anything even a little bit technical.
The same goes for the Solitude. It goes upstream with almost magical ease when poling it, but it's strictly a flat water exercise - for me, anyway.
Go the other way...I poled the MR Guide on some pretty rough water, and it turned easily but was slow going. Same for the 14' Wenonah Fisherman. That boat was the most maneuverable thing I've ever poled (edging it was amazing), but slowww upstream progress. It was way easier to stand in though than the similar length Guide.
Now go sideways. The OT Camper is a pretty good poling hull.... until things get rough. Take the Coho over the same rough water, and its way more stable. Now do that in the NC Prospector 16 and it's like standing on the sidewalk.
Maybe it's because for years I poled way more than I paddled, but it seems to me that every little difference in hulls is more pronounced when standing with a pole.
I am really happy with the Coho for most of my poling use, which includes some multi-day trips up class 2 rivers. But I still pine for a lightweight replacement for the Prospector I sold. The things I could do going down river while standing in that boat were beyond compare.
Very interesting. I think I don't have enough time in boat to notice the differences to such a degree yet. I certainly do notice differences. I think there's a bit of a feedback loop where more experience makes the differences more noticeable, and but a more experienced poler (or paddled) will be able to get by in a wider variety of hulls (tho simultaneously they will be able to better take advantage of differences btwn hulls too). Same goes for paddle designs I think.
I don't actually know what the specs on the Coho and how it compares to the NC Prospector or the Souhegan for that matter. I recall reading it's a bigger version of the Souhegan? The Souhegan has a lot of rocker - but I guess the Coho has less than an NC Prospector? I've often wondered if an NC Prospector might be a nice poling and paddling boat - interesting that it sounds like it turns too easily for you, as I often feel about the Souhegan.
I also have an OT Penobscot 16 in the garage, but haven't poled it as much since it's that much heavier than the rest of my boats and because I don't usually pole with a tripping load that necessitates the bigger boat. Is the Malecite too straight-tracking for technical water? The Malecite has also popped into mind from time to time, and of course the MR Explorer seems popular as well with polers. Good to know abou the Camper too - one of those hulls was for sale around me last year (needed new woodwork) and I was tempted but decided it was redundant to the Heron and Penobscot.
Yeah, that sounds about right.
Prior to contacting Kaz, I had learned enough to know I wanted a dedicated poling canoe and I knew it would be either the Souhegan or the Coho. I had conversations with people on a couple of different forums (not here) who had experience with one or the other - or maybe both. There seemed to be a consensus that - to put it simply - the Souhegan was best for play and competition, and the Coho was best for tripping. Since tripping in it was my intent, that's what I ordered. And it has been a good choice, I think.
The two have some significant differences. Substantial rocker in the Souhegan, where the Coho has little. IIRC, Souhegan is a little narrower and maybe shallower too.
As far as stability, the Coho and the NC Prospector are pretty much the same. The Prospector has considerable rocker though, and mine being royalex, was more blunt in the stems. So while the Prospector would spin on a dime while lightly loaded, it was definitely a slower canoe. The Coho climbs upstream noticeably easier than that 16' Prospector, and it has similar capacity.
I wouldn't say it turns too easily, but that easy turning comes at a price - as noted above. Coho's higher efficiency comes at a price too. It requires more aggressive edging to make quick turns than does the Prospector. I expect the difference would be the same between the Coho and the Souhegan.
I will say this about the Prospector - for someone pushing the limits of their poling skill, it's a fantastic platform. Very forgiving. I learned a lot in that boat, and got away with some stuff that really surprised me.
It's been a long time since I had the Penobscot, and even longer since I had the Camper. What I remember most about the Camper is that it seemed like I could almost float that canoe on a wet sidewalk. Very little draft, and the flat bottom was especially good sliding over shoals. It turned well too, but attempting to climb turbulent class 2 drops ended in numerous baptisms. :D
The Penobscot, OTOH, while it was the most tender tandem I've had, was very stable in the rough. Definitely a straight tracker though, and not as dry as the Prospector, the Coho, or even the Malecite FTM.
My Malecite has a completely different character as a poling canoe. Because it came with a center solo seat, it trims best going upstream stern first. Because what little rocker it has is in the stern, it's maneuvers well against the current that way. But the stern also has less shear so I have been reluctant to try poling it up any sizable drops or waves. I'm not sure how it would handle with the seat removed and poled bow forward. Hmmm. I need to try that. Of course, the shallow vee has that unique feel - not as steady as the shallow arch hulls.
I poled an Explorer one time. It was one I bought for my son who lives across the state, so I haven't ever been back in it. My impression though was that it was a very capable hull for poling, but a personality heavily influenced by that vee. I actually liked it, but find the differences of the ride while poling (and that of the Malecite) hard to describe. Their odd character paddled empty is well known. But when poling, I don't seem to notice it as much. Seems like they do excel at the off-side carve.
Yeah, a good poler can certainly get by with any of a lot of different hulls. The fact that Maine guide Lisa Dehart poles a Camper in all the videos I've seen - and on some pretty technical and unstable water - tells me she's got mad skills and could probably pole anything.
Me - I'm just a so-so poler obsessed with detail, so I gotta try a lot of boats.
Great break down, thanks Steve!
The Souhegan does sound like your NC - lots of rocker and very blunt in the stems. My suspicion is that the Heron (an oil-canning, slow-paddling boat) actually helps climb a straight chute because the ends are pointier and there's less rocker than the Souhegan, so when trimmed heavy in the downstream end while climbing, you have more acting to keep the boat tracking parallel to the current. But I need to climb the same drops on the same days to confirm that suspicion.
Do you have specs for the Coho? While I have the receipt from the original owner of the Souhegan, I don't have specs on it and it seems the Millbrook website is no more.
Unfortunately, I don't have the listed specs. I'm sure Kaz would provide them if asked. Just measuring the Coho as well as I can, I get 15.5' long, 35" wide, 12.5" deep at the yoke, 16" stern, and 17" bow. Shallow arch bottom, slight flair (not as much as Souhegan IIRC), and straight sides in the middle with soft chines.
Thanks! I actually emailed him last night. The Coho doesn't sound too much bigger than the Souhegan. I imagine rocker and sharpness of the stem are among the key differences.
Wellllll......I have to eat some crow now, and thank the heavens for a supportive wife who has not made me start sleeping in the boat stable - er garage - yet. Yesterday I brought home a Royalex Morningstar that popped up locally at a very good price. It has noticeably blunter stems than the composite Morningstar (expected) and seemingly fairly blunt stems compared to my Rx Heron (a bit more surprising to me). It has a solo center seat as well as the two usuals, all on aluminum drops.
I'm very curious to see how it compares to the composite Morningstar....just need some liquid water to do so, which might happen this week with rain turning to snow tonight/tomorrow and 55 on Tues. I'm probably not bold enough to get a new boat on moving water this time of year....but I'll try it on flatwater if I can.
It needs the thwart behind the center seat replaced. When hefted, it had a lot of give gunnel-to-gunnel. I'd have thought the 3 dropped seats and remaining thwart would give it enough stability, but maybe not. If I were to keep it long term*, I'd look to drop 2-3 seats for weight reduction and room to move while poling, adding back in a center yoke. The seat drops are unfortunately rivetted into the vinyl(?) gunnels so getting them out would be a bit more permanent and laborious than just undoing some bolts. I suspect as with the composite Morningstar the center solo seat is too wide a paddling station for my short stature, and as discussed above, bow seat backwards isn't taking advantage of the boat's design. I guess I'll try all three seats first before making any changes. I wonder if the wood drops in the center seat of the composite would work with the vinyl gunnels? I was planning on taking that seat out anyway to free up some room in that boat.
I really need to get on the water in 2025, do some side by side comparisons, and make some decisions. The fleet now needs trimming by 2 boats instead of 1. I truly can't fit anymore in the garage.
Oh also, I heard back from someone at Millbrook, presumably Kaz tho they didn't say, that the molds for the Souhegan and Coho went to Hayden's daughter after he passed. So presumably those boats are truly no longer being made, unless someone has new molds made off existing boats. I wonder how many of each exist.....
Congrats on your new boat. Bell royalex with vinyl gunwales is a good setup for rocky rivers. Hanging seats from the gunwales should work fine if you go that way. I added cup washers to that setup on a royalex northwind and think that helped since the screws were routed into a channel on the vinyl.
