What is a good cheap solvent for removing sap from a composite hull (besides elbow grease)?
actually even worse, some pine sap is actually acidic enough to eat into some types of clearcoat as I found to my dismay when having bodywork done to my old van, a simple touch-up turned into stripping and replacing that clearcoat when they discovered that the sap had eaten it.Actually pine sap ( eastern white pine) doesn't flake off autos when dry
It becomes welded to the finish snd only a little comes off unless you use sandpaper which is a bad idea
It does come off glass but paint nope
Try Baby oil.
Skin So Soft! A modern day miracle that will cure all kinds of ills.On paint or a hard surface like a canoe, hit up the local Avon rep for some Skin So Soft. No elbow grease required and you smell nice too.
Not sure what to use on tomatoes though... Maybe throw them in a blender w/ a little gin?![]()
Its not every tomato. Just once in about every ten. Its easy to field sample but a jolt when you expect a summer tomato taste and get a taste like varnishOn paint or a hard surface like a canoe, hit up the local Avon rep for some Skin So Soft. No elbow grease required and you smell nice too.
