• Happy Birthday, Robert Frost (1874-1963)! 🧱🛣️
Heat sensitive glue for grips?
Anyone know of a readily available glue that loosens with heat? I'm about to shorten a couple paddles and add symmetric grips to a couple others (pic shows my new Bending Branches symmetric grips) and it would be nice to use a glue that loosens with heat like Zaveral/GRB versus the permanent glue used by Bending Branches. If I want to change length again in the future (as Ivshrink) or if I destroy a paddle and want to recover the grip a heat-sensitive glue would be best.
I have a few SUP paddles from Kenalu and they use regular hot melt glue for the joints. I have reconfigured things several times using a heat gun and more hot melt glue. Been using their paddles for four or five years without any issues. They have a video on assembling paddles on their web site. https://kenalu.com/pages/assemble-your-paddle
I have also used five minute epoxy on a canoe paddle that I took back apart with judicious use of a heat gun and patience. In my opinion, hot melt glue is the way to go.
Hope this helps,
Tom B
THANK YOU guys! I'll use hot glue, I can't believe I couldn't even think of hot glue. I'm glad I didn't rush it and use epoxy. That's a nice video too. It's been a long time since I've shortened a carbon fiber paddle and I followed the same steps but I was mostly making it up so it's comforting to watch the video. Thanks again.
Another option might be rubber cement, easily softened with heat. I'd think epoxy would be a bear to get hot enough to break the bond in wood. I've replaced carbon Zav paddles, and it took a lot more heat than I expected. Hot glue might be the ticket.
I like the hot glue idea too.
I've taken grips off a half a dozen Zav paddles. Only one (the first and oldest) did the grip come of relatively easily with heat. The rest I thought something was going to break.
Epoxy is heat sensitive. Heat-resistant epoxy is available, but epoxy generally softens around 200F.
Like Alan, I've shortened a Zav. I used heat to loosen it and put it back on with fresh epoxy.
Thanks again for the feedback everyone. I never would have thought of rubber cement (or red locktite) either. On the Bending Branches paddle I want to shorten I learned that their shafts are tapered at the grip end so the new symmetric grips are a loose fit so I need a stiff glue to take up the slack. They told me that their glue just gets stronger with heat so I have to cut off at least 2.5 inches to remove the old grip and get back to hollow shaft. I may not insert the new grip all the way...to help fine-tune the length.
I've also shortened Zavs in the past and I think only one grip came off easily. I bought a heat gun which should work better than a candle. I'd like to put a symmetric grip on one of the Zav's that I shortened in the past so I'll learn whether the epoxy I used softens with heat.
I can't find our hot glue gun so will look around a little more before buying another.
I'm pretty geeked about fine-tuning a few paddles to (hopefully) get paddles I will use without investing in more paddles. Will share some pics when I have results.
go to an archery shop and get a couple of sticks of arrow nock adhesive, it's a hot melt but takes more heat and is stronger than the retail stuff, I melt it with an alcohol lamp.
Gumpus, I've had the same kind of thought to improve the grips on various paddles. I assume your picture is of grips you cut or removed off existing BB paddles. If not, can they be special ordered from BB?
Epoxy is hwsseat sensitive. Heat-resistant epoxy is available, but epoxy generally softens around 200F.
This was good to know today. With my new heat gun I was able to remove a grip from an older Zaveral that I had previously shortened and re-epoxied and I had assumed that the epoxy was permanent.
I used the nock adhesive in the 80's so when I saw your post I visited the new local archery shop and got some. They asked me if I wanted blue (for carbon fiber arrows) or higher temp yellow for aluminum so we went with blue and it worked perfectly. It was also easy to redo when I put one handle on backwards. Thanks for posting.
Click image for larger version  Name:	20210429_152133.jpg Views:	0 Size:	246.3 KB ID:	124582
Dave. Bending Branches sold them to me for $30 each which I thought was perfectly fair. It's not a catalog item so they just decided on the price when I asked to buy a grip. FYI the stub in the handle is 2.5 inches long and since they taper their shafts the grip may be a bit loose if you stick them into a Zaveral shaft for example, but a little glue takes up the slack.
The grip is the one used on their current Sunburst. I have a previous gen 56" Sunburst XL that fits me perfectly and inherited a 56" Sunburst with smaller blade and I want to shorten the smaller bladed Sunburst and add a symmetric grip.
So here are some results. I've put a lot of miles on 56" straight shaft paddles with short blades. On far left is a now 54 5/8 " straight Zav with rare symmetric blade...with new symmetric grip. I gave this paddle to a friend many years ago and recently got it back when he stopped paddling. In the middle is a now 55 1/8 inch straight Zav just shortened from 56. On right is a 56" straight Black Bart Troublemaker for reference. I'm looking forward to using the updated paddles over the next few days.
Thanks for the info. I agree, $30 is fair for the grip. BB should put them on the website. We can't be the only ones thinking this way. Cheers.
