• Happy Tear the Tags Off the Mattress Day! 🛏️✂️🏷️🚔🚨👮
2016 Northstar Polaris
very little if any when compared to the aluminum. If you call them talk to Bear. He can give you a definite answer.
Northstar web site states:
Trim Options
Wood:
Oiled white ash gunwales; sculpted and laminated black walnut and ash end decks; walnut and ash laminated contoured web seats hung on walnut trusses; walnut and ash laminated thwarts and yoke; stem mounted tie down loops. Laminated black walnut and ash creates a distinctive and refined canoe that is stronger and lighter.
I emailed Northstar and got a reply that wood trim adds 3 pounds to a Polaris. I believe that would take the total weight from 38 Lbs. to 41 Lbs.
Measurements
Length: 16ft 9in
Length/Width Ratio: 6.5
Width: 31 gw / 34.5 mx / 31 wl
Sheer: 20.5 bw / 13.5 ms / 17.5 st
Rocker: 2.5 bw / 1.5 st
Weight: 38 StarLite / 41 BlackLite / 50 WhiteGold
6h freeboard: 950 lbs
Optimal Load: 250-550lbs
Displacement:
2h WL : 170 lbs
3h WL : 310 lbs
4h WL : 420 lbs
5 WL : 580 lbs
I will weigh mine to see how close it is to Northstar's published information.
