Check out the 5[SUP]th[/SUP] photo. The seller does refer to it as “a brutal hack job”
http://nh.craigslist.org/boa/5672224341.html
Truth in advertising is refreshing.The seller does refer to it as “a brutal hack job”.
Typically, an asymmetrical hull does not refer to the difference from the left side to the right!![]()
It sounds like the seller was throwing in a board to do it right, so that's good.
I was thinking more along a mahogany table top..! uh except we do need to steam bend mahogany for an old Robertson anywayI hope whoever buys it knows how to steam bend wood if they try to use that mahagony.
The Osprey was only 13 feet long, but 39 inches wide, so not only is there is a lot of ( ) going on in a short distance, but it also has 10+ inches of stem rise, 11 ½ inch center and 21 inch bow and stern.
This is what the canoe should look like
http://www.youtube.com/watch?v=2ZTFL_y8WoM
