Pet food containers for flotation and storage
North Carolina
Summay
Gamma2 Vittles Vault 85lb animal food storage containers (square barrels) were used as flotation and dry storage. The lids were pleasant to open and close but were not completely watertight. Ultimately most paddlers will probably find blue barrels superior.
Since it's dark and cold out I'll elaborate on the barrels, lashing them in, testing, and some drawbacks.
Part 1 - Why the square barrel?
I like to carry flotation in whitewater and open water. This is based on my past swims, practice sessions, and the norm for dedicated whitewater canoes. My goal was not just to keep stuff dry, but also to have something that would function like an air bag.
60 L blue barrels are a well established dry storage solution. However, I find the metal rings fidgety and irritating. I found the Gamma seal lid to be satisfying to spin shut. I also like the neutral off-white color of the square barrels.
I could get new, clean square barrels to my door for around $80 each. I couldn't find blue barrels below $120 with shipping. I couldn't find used blue barrels nearby either. Somebody an hour away was selling them, but they never seemed to have several 16 gallon available at the same time. He was also removing the labels, making it impossible to know what was originally in them.
So at Christmas I suggested it to my wife, and shortly a large square pet food container was beside the Christmas tree with a red bow.
Part 2 the square barrel
Christmas morning I removed the bow and tags then gave the lid a satisfying spin. I quickly noticed a problem - there hadn't been adequate (any?) post-mold cleanup. There was sharp flashing left on the lid, ring, top and bottom of the barrel. Some places were sharp enough to cut fingers. I used a razor, flat file and sandpaper to smooth it out. A chainsaw file helped get inside the threads on the lid.
I measured the square barrel to be 28 ¾ x 14 x 14 inches. The opening is 10 1/2 in across. It weighs 6.4 lbs. I'm estimating the volume to be 87 L.
The lid is a Gamma seal bucket lid, and the barrel is basically a big tall bucket. A good tug will remove the lid collar from the barrel.
Part 3 - Outfitting the Lamoille and the first test.
The barrels were first rigged behind the yoke in the MR Lamoille. This is mainly due to my current 2-kids-in-tandem front seating arrangement. It crowded into the rear paddler's foot room, but it's tolerable. It would be fine if the seat were moved back a little, but the kids aren't heavy enough yet.
The picture shows the prototype lashing. The boards across the top of the square barrels are lashed to the portage yoke and rear thwart. This snugs up everything nicely and keeps the barrels from popping up.
The barrels were each loaded with a 20lb bag of kitty litter to simulate the intended load of sleeping bags and clothing. A test flip and reentry was performed (the green unsecured tote was removed). I was able to right the canoe, climb in, then bail the remaining water.
The test was a technical success, but there was some water in the barrels. It wasn't much, less than a quarter cup. That isn't enough to flood the barrels, but would be enough to make sleeping bags or clothes feel wet.
That's all for today, field testing next.
Interesting to hear about the Gamma Seal lids leaking. I use them for various applications including holding ballast water in my tandem when paddling solo. I haven't noticed any leakage yet.
I had looked into the smaller Vittles Vaults as an alternative to 5 gallon buckets thinking that they would be more comfortable against my back in a Duluth Pack. I ultimately decided against them and stuck with my original outfit (plastic bag liners and steel mesh bags to protect against rodents.) No regrets.
Thanks for reviewing, I've been curious about those for a while. Right now I use a couple of buckets with gamma seal lids, one 6 gal one 3.5, but they're far from perfect. Round objects are annoying in a canoe.
Part 4a- Field testing - Lake Trip
The barrels were used in the Lamoille (Moose) during a long day trip on Lake Jocassee.
We launched from our campground, which required a 120 yard carry. The barrels have only indents for handles, and I wondered how they would carry. Empty we had no trouble getting them down to the water, or back afterwards.
We tied the barrels in with a version 2 lashing. A cam strap was used to zigzag across the canoe, with the board used to bridge the portage yoke and rear thwart. The only difficulty was a northern water snake who swam over to check out Moose and remind us to watch our step.
With the barrels side by side we were able to access the lids. I tossed in our dry shoes and a few snacks. As usual we carried the crash kit (first aid kit, repair kit, etc) in a dry bag.
Moose at "Holy Island", the last stop before the 0.8 mile crossing toward Fisher Knob, followed by the 0.4 mile hop toward Double Spring Mountain.
There was no drama on our trip. As noted in the pool the barrels took a little of rear sprawl space. It was acceptable but not ideal. I was happy to have easy to rig flotation and a place to toss shoes.
Part 4b - Baptism
The square barrels were far too long for the Old Town Appalachian. It has the thwart and seats pulled in toward center. They did fit sideways. The only drawback was there's very little access to the barrel once it's tied in.
I setup for white water with a barrel in the position shown, with an airbag farther back (forward). I paddled solo from the front seat. My preference is for airbags in the ends, but but that will have to wait for another day.
During the run I took in two to three inches of water in the top of a class 3. The floatation worked as expected. It did a good job keeping the water from sloshing freely as I navigated the rest of the rapid.
The water was in the canoe for about 5 minutes. In that time a quarter cup of water leaked in, dampening one of my shoes.
I threw a few things in the barrel for the 150 yard walk to the parking lot. This time the indent handle felt lacking, and I was ready to have it out of my hand by time I got to the end.
I, too, have been interested in these for a while so thanks for testing them out. I use pails with Gamma Seal lids and have not had them leak (yet). I'm surprised that yours leaked. Thanks for keeping us informed about your testing.
Part 5 - seal improvements
I want to reduce the leakage. However, I don't know if the barrel-to-collar or collar-to-lid seal is leaking.
The collar can be pulled off fairly easily. For sure a bear could do it. Maybe a big raccoon. I decided bonding it to the barrel would be the first step. I was also hoping removing the o-ring would shorten the barrel by a cm
The plastic is fairly slippery, and the barrel to collar joint is fairly tight. I was doubtful regular caulk would work. But I figured the joint is tight enough the caulk might bind everything together even without perfect adhesion. Besides, determining and sourcing a proper solution is work.
I removed the o-ring then , cleaned everything with 98% isopropanol. I tried clear outdoor caulk. Nope. The joint was so tight the caulk wouldn't set. I left it in warm spot for 12 hours, and in the garage overnight. No luck. Only a few sections set up.
I wiped and peeled it off then reassembled the joint.
I ask Microsoft's AI assistant what adhesive to use. It gave a good explanation, but I'll still have to select a product.
Part 6 - A Real Trip
We used the square barrels on a two night trip. Two 20 degree mummy bags and sleeping pads fit nicely, taking a little over half the space. We filled the rest of the first barrel with clothes and such. Finally, a frisbee on top. This worked great, keeping the contents from getting tangled in the lid.
The second barrel took the remaining bedding and packaged food in a stuff sack The barrel has to be handled carefully to avoid damaging the food while laying it in the canoe. I put the fresh fruit and open food in the wannigan with the stove to avoid contaminating our bedding with food smells.
Our big 4 person tent did not fit rolled in the factory bag. It was too wide for the lid. We'll find different bags for the tent and fly so we can insert each separately. This wouldn't be a problem with a smaller tent.
Overall the square barrels packed nicely.
The square barrels worked great at mealtime. The flat sides work great as counter space. With both barrels sideways on the ground I was able to plate meals for three people, just like I had a countertop.
I am a little concerned the plastic is relatively thin. I was careful not to sit anything too hot on it.
