• Happy May Ray Day! 🌞😎🌻🩳🇩
Canoe ID and restoration
CT & NY
I'm trying to ID a canoe I acquired a couple of years ago (ah, the "free" canoe). Actually it was a swap; my brother in law gave us a cheapo Coleman plastic canoe (the kind with the aluminum tube frame). I never did much with it as I had another [ancient] fiberglass canoe, but I found that a YMCA camp down the lake where my daughter works as a nurse had an old canoe needing woodwork but otherwise solid... and they also had a bunch of the Coleman canoes, and agreed to swap.
Anyway, it's a Royalex hull with wood gunwales, thwarts, and cane seats, just over 16' long. I suspect it's a Mad River, from the place where there was once a long rectangular sticker amidships, but it could be a We-no-nah as well? There are no other markings that I could find.
As you can see, all of the wood needs to be replaced. I originally intended to buy everything from Ed's, but when all the ash trees started dying we (at our camp) bought a sawmill to cut them up for lumber, and as ash is traditional for canoe parts, I'm going to make the gunwales and thwarts from the trees that once grew around the lake it'll mostly be paddling on, just seems appropriate. I'll still buy the seats from Ed's, probably the contour bucket, at least for the back.
The other question is about refinishing the hull. It's solid, a couple of minor gouges but no cracks, but large parts of the surface have crazed, almost like orange peel from a bad spray paint job, but it wasn't painted that I can tell. Presumably it's UV damage to the outer layer. What's the best way to refinish a Royalex hull? The outer layer is vinyl, is it not?
png photos dont seem to download alas
latee they do
Like most of you i hate computers!
I can see the pics on my iPad. There should be a hull id number on the stern in the right side near the gunnel. That will help a lot in determining the builder. I can’t help with the royalex care as I don’t have much experience with it.
It does look like a Mad River. Shallow V hull, on-top decks, wood rails on an Rx hull (not really a good idea, but the Mad River people loved the wood).
Yes, the outer layer is vinyl. You might try touching it up with the fancy 303 protectant, or just some automotive products (Armor All and friends) intended for old vinyl. You could probably sand it lightly to reveal brighter/smoother vinyl, but that would be tough love. I'd try just a green scrub pad.
Good luck with it, looks like a nice hull. Do post pictures as you work on it, people here like to watch.
Looks like a Mad River to me also. What's the beam at the widest spot in the middle? The popular Explorer model should be 35"-36" depending how you measure.
The serial number should be scratched under the gunwales probably at the stern. The last two digits would be the year of manufacture.
You could put a wide cane seat in that canoe about 8" aft of center so you can paddle solo with level trim. I did that with my Mad River Explorer, which was my first canoe and which I still have.
The deck plates do look like those used by Mad River Canoe. If so, MRC embossed a hull identification number into the hull material of their Royalex canoes on the outside stern but you often have to look very closely to find and decipher those embossed characters on an old hull.
Made some more measurements last night, looks like 37" beam measured inside the hull... but it's so wiggly without intact wood that could be off a bit. The thwarts are 31 and 34.5". No center thwart or yoke, I may decide to add one.
No numbers anywhere I can see.
Has anybody used the bucket seats from Ed's? I like the idea, but I'm guessing it wouldn't be suitable for the front seat if one wants to sit backwards in the front seat when paddling solo?
This is a closeup of what parts of the hull look like. Sanding smooths it out nicely, so I'm hoping it will be a decent base for new paint... but what kind of paint?
I thought I posted an update last week, but it seems to have disappeared... anyway, I got it all apart. Getting some of the screws out was a struggle; they're square drive, but it looks like somebody tried to tighten them with a phillips screwdriver and trashed the heads.
I did find a number, 4117, written in magic marker on the inside of the hull inside the deck plates, but nothing embossed.
Under the deck plates, there are blocks that look like Trex plastic deck boards, which reinforce the nose and also support the carry ropes. Not sure if that's original? I'll be remaking these, if I can find some Trex scraps laying around (probably).
I edge rounded the boards that will be the gunwales, and cut and shaped the thwarts. I had to buy a new router as the old one's collet was shot and no replacement was available. No pix yet.
Next us to rip the gunwales to width, but I came down with covid which pretty much trashed the rest of my vacation. I'm hoping to get those done tonight, then to cut them on an angle for a scarf joint in the middle. I'm planning on Titebond III for that, but could use epoxy... thoughts?
Slow progress continues. Got the gunwales ripped and scarfed last week. Saturday I glued them together to get the required 16' lengths using West System epoxy reinforced with microfiber (I decided against Titebond as that needs a perfect glue line with no gaps, epoxy is a little more tolerant). I drilled for two dowels in each joint to keep things aligned. I only had enough clamps to do two at a time; the first two went great but that last two I did in the evening after the mosquitos came out so the second two were a bit messier, with a bit more sanding of the squeezeout needed, which I did on Sunday, followed by final sanding of all the parts.
Hopefully this weekend I can get everything drilled and assembled, then back apart for finishing. The seats came prefinished with polyurethane, I plan to use teak oil on the gunwales, but I'm not sure about the seat hangers and thwarts... poly or oil?
Here are some pics of one that sold here in CNY for 300$.. states is was MR
The canoe is probably an explorer, if it's 16 feet it's the most likely. That closeup of the hull looks like peeling paint. If so, just sand it off like you said and use rust paint if you want to go the inexpensive route or go with a marine topside paint from interlux or petit. If you stick to green, you might be able to get by with 3 coats and only use one quart. Others on here have painted royalex canoes with these paints and had good luck. I'm surprised it has two thwarts instead of a yoke and a thwart or just the single carry yoke. All the explorers I've seen have a carry yoke.
Mark
Mark
I think we have a winner! Pictures in this advertisement look identical to what I have, so circa 1985. Only the thwarts are different. Although, the ad says 17' and mine is 16'.
Another ad for an Explorer mentions the number written in permanent marker, just like mine. I guess the design changed over the years; that one shows a single thwart and carry handles, which mine doesn't have.
