Left outside, on the ground, without cover for quite a few years, this 23 year old canoe was in sad shape. Nonetheless the canoe's hull was in good shape. After taking off the adaptive seats made of 3/4 inch pressure treated marine plywood, the canoe weighed in at 45 lbs. Pretty light for a 15 foot tandem and worthy of saving.
BEFORE
All the wood rotted, seat webbing rotted, a carry handle missing,
Gunwale powder coating eroding off, a black crud covering the hull everywhere
Desk plate pock marks
Rivets corroded and failing
AFTER
The rebuild included:
Wet sanding 3 times took all the black crud off the hull - using 400, 600, and 1,200 grit
Drilled out and replaced 64 rivets, not taking any chances on more rivet failures
Painting - Gunnels brushed with an enamel paint on the first coat and then rolled on the second coat. The result was a lightly textured, yet very smooth feel. Spray paint for the deck plate
Repair Investments
$120 - wood work
$35 - brush and spray enamel
$7 - rivets
$15 - wet sand paper
Total - $177
The project had me purchase two new tools - a random orbital sander - thanks for that suggestion MIke, it sure made the project easier. And another item that while not essential, really helped expedite the work - a wheeled shop stool.
PHOTOS
BEFORE
AFTER
Repair Investments
$120 - wood work
$7 - rivets
Total - $177
PHOTOS
