• Happy National Eggnog Day! 🎄🥛😵
Riding Mower Way OT
Penacook, NH on a back road
Time to change the blades on Free to Me Riding mower, hadn't done it in 5 years and the old blades were cutting the lawn in a mohawk haircut kind of way. Now the b*tch on changing blades is finding a way to rise the front end enough to get at the bolts and I've tried a few different stupid and almost dangerous methods on previous mowers. This time while looking for something I found some hemlock that was used to build a new shed roof a couple of years ago. Cut for the Birds Mouth so they were angled and long. I ended up screwing three together and then another three and bingo, ramps with ample room to get my arms in to unleash the bolts and clean the crud of thick dried up grass off and install the new blades. Nothing fancy, left over wood and it works.
dougd
Bet you could jump the Grand Canyon with that setup. Might want to raise the mower deck waaaay up.
Be sensible and wear a helmet.
ps And a parachute.
Deck is raised as high as it goes and the brake is on. I did have a chuck on the back wheel. I agree Kim, mowing the lawn is a huge waste of time and money but my lawn is big enough to enjoy a few beers while mowing it.
So a lawn that's so big it takes several beers to mow it, and a mower that leaves the lawn patchy...you both get half cut? lol
I agree that modern monocultures of grass grass grass are a waste of green, in every sense of the word. But they are also nice for the kids to play on, and places to pitch tents, horseshoes and baseballs. And it's as good an excuse as any to crack open a cold one.
High maintenance. (lol)
When I worked under the mower deck I used to just jack up one end or the other with a floor jack. Picked it up a foot or mower, which provided plenty of space under the deck. Also, more mower accessible from the side, as your ramps kind of block access to the under-deck area. But you got those ramps and they seem to work fine.
I'm channelling Billy Idol. "mower, more, mower"
Please finish mowing and post about the St. John trip. The St. John was my first river trip and provided some great memories. I kind of wanted to make that trip again, but it's not happening this year. Sorry to get off this off topic but inquiring minds want to know.
Doesn't that mower deck detach and come right out? It is a bit of a pain in the butt on my mower to get it detached (something like 7 C-clips to remove, and then put back) but it only takes maybe 5 minutes, and I can just slide the deck out and have my way with it. Much, much easier to clean out the crap and change the blades.
-rs
Belly mower decks usually detach, but perhaps some brands don't.
Doug used an inexpensive DYI approach. I've used wheel ramps and a hi-lift jack on my tractors. Jack stands should work. For money.
Yeah I had to change a blade last week when I hit a rock. Nasty business. Mine drops out pretty easy with a few pins ...makes the work pretty easy. I bought another old tractor last night with a tiller....I am getting quite a fleet here.
I started trying the clips but they were a PITA to get to and using the cheap and simple ramps worked just fine. Besides it only took about 10 minutes to swap out blades and I figured it would take me longer to remember where the hell the clips went back in!
Newer tractors have an ingenious system of throwing a switch to unlatch the deck and driving off (now several years old), never having to leave your seat, and older lawn tractors have the cotter pins. No idea how yours is set up Doug, but I remember it was always nice to be able to service the deck with IT laid out on the floor rather than ME laid out on the floor. My lawns are small enough for me to follow a little self-propelled mower around in about 20 minutes. Not enough time to open a beer. I don't miss lawn/mower maintenance.
I was just kidding about the Grand Canyon thing, helmet and parachute...some people might take it as a challenge, which can start with this https://www.youtube.com/watch?v=to8wh7LScXI , and lead to this https://www.youtube.com/watch?v=QT_GlAQpi5s.
Personally, I'd stick to cutting the grass.
Theoretically, my mower deck detaches easily, but in practice, it's way easier to jack it up to change blades. It needs to be high enough to get an impact wrench under the blades to loosen them.
I enjoy cutting grass, I worked at a sod farm for two years and cut 120 acres a week. It was nice of Christy to get a 17hp tractor for me and it still takes over an hour to cut our 2/3 acre lot. She occasionally will cut it when I am coming home from work since she likes cutting as well, ha ha. b***h. Most homes have Kentucky Blue blend, which is high maintenance, very thirsty and grows fast. Under ideal conditions, 75F and 40-50% humidity, it will grow 3/4" overnight. If you have Kentucky Blue and you like to cut grass, you should be doing it twice a week. I'm sure you have a mini fridge on the hood so this allows more consumption as you are actually helping it by cutting it more. Grass grows, if you leave it, it grows up. If you cut it regularly, it grows a better root system which makes it better grass.
If you have had a week or so without rain, you can look at it and it will tell you if it is distressed. The blades will cast a dark purple or black on the backside of the blades, or technically, leaves. If it is showing this, don't cut it. It harms the grass to cut it when it is distressed. Don't worry if it goes further, it isn't dying, it is just going into hibernation until conditions improve for growth. If that happens, then just sit on your tractor with your beer, look at the grass and save fuel.
Our lawn has some grass in it, also quack grass, various weeds and a plethora of dandelions. We don't treat any of it and we don't water it. It isn't a status symbol for us. It is natural in this state and although I miss cutting it weekly, it is ok to let it live how it needs to be.
Karin
