The first coat of EZPoxy went on EZ.
Half of the first coat; it was more roll on/tip out efficient working from the keel line down to the gunwale on each side.
PA261301 by
Mike McCrea, on Flickr
The taping wasn’t hard, but the deck plates, painter eyes and HIN were as time consuming as the gunwales.
PA291303 by
Not too shabby. I missed a little paint along the edge at the gunwale line with the first coat.
PA291307 by
But mostly it came out well.
PA291308 by
The second coat of EZPoxy has been rolled and tipped. The rolling and tipping out is the easiest part of course, like any boatwork most of the time is prep time; cleaning, wet sanding, taping the gunwales, painter holes (I epoxied the caps on firmly years ago, they weren’t coming off) and HIN plate, laying out tools and materials, making sure everything is at the ready.
What did I forget to lay out. Oh, yeah, acetone, and a rag. And spare gloves.
And other spare gloves; DougD sent me some Dollar store disposable gloves. Not only are they disposable, they are also dissolvable with acetone. I think Doug finally got me back for the box of purple Nitriles I sent him. Box carefully opened, first 8 gloves slit with a razor along the middle finger, neatly repackaged and sent off to Doug.
Doug called to mention some mysterious defect with the gloves. He got as far as “Hey, about those glov” before all I could hear was laughter. Me, cackling like a madman.
Good news/bad news. The Malecite needs a third coat of EXPoxy. The good news is that I have enough of the quart can to roll and tip the Malecite a third time, with (maybe) a half pint of paint left for future touchups.
The good news about the 3[SUP]rd[/SUP] coat is that I really didn’t want to wet sand it and tape it for a 4[SUP]th[/SUP] coat.
The bad news is that the 2[SUP]nd[/SUP] coat is noticeably sloppier than the first. Working with white paint on the yellowish epoxied hull it was easy to see any drips, sags or missed spots when tipping out.
The white-on-white second coat, not so much. I’m still not doing a great job just at the edge of taped over gunwales. Of course that is most noticeable when viewed at the 12 inch mark while staring at the underside of the outwale; the Malecite already passes the 30 foot test.
One more wet sanding, one more taping, one more coat of EZPoxy to go. That’s all I have in me before moving on to some new project and making dust in the shop.
PA311313 by
For anyone counting, I washed and elbow grease scrubbed (vinegar and Dawn) the Malecite five freaking times on the initial work day trying to get it clean. I acetone wiped and epoxy coated it, wet sanded the epoxy once cured, taped it again and EZPoxied painted it, wet sanded that paint coat, taped and EZPoxied it yet again.
FWIW a quart of EZPoxy should cover that canoe three times with a little left over. The Malecite is 16’ 5” long, 34.5” widest, 13” deep. A quart of EZPoxy would do a smaller hull four times. Have fun with that.
And, once again, for the umpteenth time, what did I
not remember to do before starting work on the canoe?
Weight it before I started dammit.
