I've had a Wenonah Heron for >6yrs now, and feel extremely comfortable paddling it solo (usually with a 65lb dog), standing, poling swamps and flatwater, etc. It has so much primary stability, I can run the front up on a beaver dam, race from one paddling station to the other, and use my weight to get over the dam without loosing too much momentum (assuming a pretty low dam of course). I love the Heron as a jack-of-all trades, but it's definitely a master of none. The bottom oil cans like crazy - I can get it to flex just by bobbing in my seat - but it's also the lightest rolayex tandem I've heard of at ~50lbs. When soloed, the ends catch the wind and it's hard to control. At 35in wide and only 15ft long, it's quite piggish. It does fine with two paddlers and no load, but starts to feel a bit twitchy with two paddles, a tripping load, and the dog. Or two paddlers and dog excited by a beaver or loon popping up near the boat.
One of the closest water bodies to me is a small creek (some Class I but mostly swift flat-ish water with riffles and shoals, as well as deeper pools). The creek is mostly only floated/paddled in spring by locals - then the water drops and the trout anglers reign. I'm working on practicing poling in current on the creek - I was out for about 90 mins in the Heron this weekend, working a single reach with a swift riffle at each end, with decent success. Eventually I hope to be do some half-day outings, working up river by pole and floating down. I don't want to make miles, just enjoy the moving water closest to home without needing a shuttle.
A Millbrook Souhegan has come up for sale sort of near me. I like that it's about ~10lbs lighter than the Heron and made for poling. But I can't find solid spec listings for it. Will it paddle as well with me (pushing 190lbs these days) + a 65lb dog in the swamps? Is it really too small a boat for my weight anyway (see this thread)? Will it feel much twitchier than the Heron due to the narrower width? Does it paddle terribly in flat water?
I really don't have space for another boat, and already have too many, so I think I'd need to let the Heron go if I got the Souhegan. I also have an OT Penobscot 16ft for tandem trips (a good poling boat, I know, but I don't like car-topping it myself when I have lighter options), and a composite kneeling solo for when I don't want to stand/pole or for tripping with portages. If I swap out the Heron for the Souhegan, would I giving up a versatile boat for a one-trick pony (and likely loosing a few hundred bucks in the process)?
How important are a poler's skills and practice, vs the boat itself? Will the Souhegan really up my poling game? Save me 10lbs cartopping and be equally as useful? The part of me that rails against n+1 consumerism says keep the Heron and keep practicing.
