I brought a couple poly rec kayaks into the shop for side-by-side outfitting comparison with a friends new 2017 same-name boat* and discovered that the vinyl pad D rings I had installed to secure float bags or gear under the (un-bulkheaded) decks on both boats were starting to peel up at the edges.
It has been ages since I outfitted those poly hulls, essentially turning them into solo decked canoes with raised seats. I do not remember what adhesive I used on the vinyl pads, nor if I should have) flame treated the area where the pad lay, and there was no sign that I sealed the edge of the vinyl pad to the hull is any way. My bad all around.
Cleaned up, poly hull propane torch flamed and G/flexed, with a piece of wax paper and some sandbag weights atop to re-secure the lifting edges. Once the G/flex set I ran a bead of E6000 around the perimeter as an adhesive/sealant. Should be good for at least another decade.
While I was at the boat rack, I noticed that the vinyl Dring pad on one old RX solo canoe had popped completely free. Completely and cleanly free, without leaving much trace of adhesive on the hull or the underside of the pad.
This one was also my bad. I had put the canoe back on the rack earlier this summer with the float bags left in. While not left fully inflated, when the sun hit the canoe the bag (which is in a full cage with two webbing straps) overinflated and pulled the D ring off the floor.
I am certain that I used Vynabond on that pad; perhaps the Vynabond was too thinly applied or too well dried before installation. Not sure if a perimeter bead of adhesive/sealant would have made any difference, but (my bad #2) I obviously never applied one. At least it separated cleanly and did not tear off a patch of skin from the canoe interior.
More G/flex, and a perimeter bead of E6000 and that one is good to go as well. I do not care about the permanence of epoxy on a vinyl pad, I have the pads locate exactly where I will always want them for float bags and gear.
*It was fun to look over our two soloized rec kayaks; a Pamlico 145T and 160T. We have composite hulls converted into deck canoe trippers that we use far more often, but the P145 especially is a great little boat. But not the same hull design today that it once was.
Modern day P145 shop visitor showed up and the first thing I said, before the boat was off the roof racks, was That is not a P145.
It was, but it is not anywhere near the same boat.
Pamlico rec Kayak comparison. The earlier generation Pamlico 145T with rudder was a wonderful rec kayak design. It was not a good tandem, but once soloized with a raised seat, rudder and sail it made an awesome plastic pocket tripper or day use boat, and is still one of the best sailing hulls in the fleet.
The 2017 Pamlico 145T model that showed up is a completely different hull, not nearly the same boat and, to my design/dimension preferences, not nearly as good a hull. Harsh words, but Wilderness Systems went and ruined one of the best decked poly hull designs around.
(Pamilco 160T specs also included below; the P160 is a heavy, (deduct 11 lbs when removing one Phase 3 seat and tandem outfitting), and not very fast under paddle solo, but by gawd it will hold a lot of gear once soloized and it sails like a champ. The P160 is the closest thing available to an inexpensive plastic Kruger boat. Either of those earlier Pamlico models appear used and cheap, with rudders, from time to time.
FWIW, Pamlico comparisons.
Pamlico 145T, 2017 vs 2000 model dimensions:
Length 14.5 feet vs 14.5
Width 31 inches vs 29
Weight with rudder 73 lbs vs 66 lbs (73 lb purported weight, I did not think to weigh the 2017 model)
Deck height 16 inches vs 13
Cockpit length 90 inches vs 82
Cockpit width 22.75 inches vs 19
Pamlico 160T (back when Wilderness still made it)
Length 15.5 feet
Width 32 inches
Weight 80 lbs with rudder (less 11 lbs if soloized)
Deck height 14 inches
Cockpit length 88 inches
Cockpit width 22 inches
Basically the new P145T is the old P160, only a foot shorter in length. Ylecchhh!
Length 15.5 feet
Width 32 inches
